ARM/locomo: Prepare locomo_handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Jiang Liu
Cc: Russell King
Cc: linux-arm-kernel@lists.infradead.org
 arch/arm/common/locomo.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/common/locomo.c b/arch/arm/common/locomo.c
index ee9b192..9d124fd 100644
--- a/arch/arm/common/locomo.c
+++ b/arch/arm/common/locomo.c
@@ -138,7 +138,7 @@ static struct locomo_dev_info locomo_devices[] = {
-static void locomo_handler(unsigned int irq, struct irq_desc *desc)
+static void locomo_handler(unsigned int __irq, struct irq_desc *desc)
 	struct locomo *lchip = irq_desc_get_chip_data(desc);
 	int req, i;
@@ -150,6 +150,8 @@ static void locomo_handler(unsigned int irq, struct irq_desc *desc)
 	req = locomo_readl(lchip->base + LOCOMO_ICR) & 0x0f00;
 	if (req) {
+		unsigned int irq;
 		/* generate the next interrupt(s) */
 		irq = lchip->irq_base;
 		for (i = 0; i <= 3; i++, irq++) {
BtrLinux
Privacy Overview
