ARM/dove: Prepare pmu_irq_handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Jiang Liu
Cc: Russell King
Cc: linux-arm-kernel@lists.infradead.org
 arch/arm/mach-dove/irq.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-dove/irq.c b/arch/arm/mach-dove/irq.c
index df0223f..a50ea93 100644
--- a/arch/arm/mach-dove/irq.c
+++ b/arch/arm/mach-dove/irq.c
@@ -69,8 +69,9 @@ static struct irq_chip pmu_irq_chip = {
 	.irq_ack	= pmu_irq_ack,
-static void pmu_irq_handler(unsigned int irq, struct irq_desc *desc)
+static void pmu_irq_handler(unsigned int __irq, struct irq_desc *desc)
+	unsigned int irq = irq_desc_get_irq(desc);
 	unsigned long cause = readl(PMU_INTERRUPT_CAUSE);
 	cause &= readl(PMU_INTERRUPT_MASK);
BtrLinux
Privacy Overview
