ARM: shmobile: R-Mobile: add missing of_node_put
Author: Julia Lawall <Julia.Lawall@lip6.fr>
for_each_child_of_node performs an of_node_get on each iteration, so
a break out of the loop requires an of_node_put.
The semantic patch that fixes this problem is as follows
(http://coccinelle.lip6.fr):
expression root,e;
local idexpression child;
 for_each_child_of_node(root, child) {
   ... when != of_node_put(child)
       when != e = child
   return child;
+  of_node_put(child);
?  return ...;
Signed-off-by: Julia Lawall
Signed-off-by: Simon Horman
 arch/arm/mach-shmobile/pm-rmobile.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-shmobile/pm-rmobile.c b/arch/arm/mach-shmobile/pm-rmobile.c
index a5b96b9..424155b 100644
--- a/arch/arm/mach-shmobile/pm-rmobile.c
+++ b/arch/arm/mach-shmobile/pm-rmobile.c
@@ -342,8 +342,10 @@ static int __init rmobile_add_pm_domains(void __iomem *base,
 		pd = kzalloc(sizeof(*pd), GFP_KERNEL);
-		if (!pd)
+		if (!pd) {
+			of_node_put(np);
 			return -ENOMEM;
 		pd->genpd.name = np->name;
 		pd->base = base;
BtrLinux
Privacy Overview
