ARM: shmobile: apmu: correct type of CPU id
Author: Andrzej Hajda <a.hajda@samsung.com>
CPU id can be negative, so it cannot be assigned to unsigned variable.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Signed-off-by: Andrzej Hajda
Signed-off-by: Simon Horman
 arch/arm/mach-shmobile/platsmp-apmu.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-shmobile/platsmp-apmu.c b/arch/arm/mach-shmobile/platsmp-apmu.c
index bcf4cc5..911884f 100644
--- a/arch/arm/mach-shmobile/platsmp-apmu.c
+++ b/arch/arm/mach-shmobile/platsmp-apmu.c
@@ -88,7 +88,7 @@ static void apmu_init_cpu(struct resource *res, int cpu, int bit)
 static void apmu_parse_cfg(void (*fn)(struct resource *res, int cpu, int bit),
 			   struct rcar_apmu_config *apmu_config, int num)
-	u32 id;
+	int id;
 	int k;
 	int bit, index;
 	bool is_allowed;
BtrLinux
Privacy Overview
