ARM: S3C24xx: delete double assignment
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive assignments to the same location.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression i;
*i = ...;
 i = ...;
Signed-off-by: Julia Lawall
Signed-off-by: Kukjin Kim
 arch/arm/mach-s3c24xx/mach-h1940.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-s3c24xx/mach-h1940.c b/arch/arm/mach-s3c24xx/mach-h1940.c
index bb8d008..477778c 100644
--- a/arch/arm/mach-s3c24xx/mach-h1940.c
+++ b/arch/arm/mach-s3c24xx/mach-h1940.c
@@ -380,7 +380,7 @@ int h1940_led_blink_set(unsigned gpio, int state,
 	default:
 		blink_gpio = S3C2410_GPA(3);
 		check_gpio1 = S3C2410_GPA(1);
-		check_gpio1 = S3C2410_GPA(7);
+		check_gpio2 = S3C2410_GPA(7);
 		break;
BtrLinux
Privacy Overview
