ARM: S3C24XX: arch/arm/plat-s3c24xx: Move dereference after NULL test
If the NULL test on buf is needed, then the dereference should be after the
NULL test.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
@match exists@
expression x, E;
identifier fld;
* x->fld
  ... when != \(x = E\|&x\)
* x == NULL
Signed-off-by: Julia Lawall
Signed-off-by: Ben Dooks
 arch/arm/plat-s3c24xx/dma.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/arch/arm/plat-s3c24xx/dma.c b/arch/arm/plat-s3c24xx/dma.c
index 196b191..f046f8c 100644
--- a/arch/arm/plat-s3c24xx/dma.c
+++ b/arch/arm/plat-s3c24xx/dma.c
@@ -208,14 +208,14 @@ s3c2410_dma_loadbuffer(struct s3c2410_dma_chan *chan,
 	unsigned long reload;
-	pr_debug("s3c2410_chan_loadbuffer: loading buff %p (0x%08lx,0x%06x)\n",
-		 buf, (unsigned long)buf->data, buf->size);
 	if (buf == NULL) {
 		dmawarn("buffer is NULL\n");
 		return -EINVAL;
+	pr_debug("s3c2410_chan_loadbuffer: loading buff %p (0x%08lx,0x%06x)\n",
+		 buf, (unsigned long)buf->data, buf->size);
 	/* check the state of the channel before we do anything */
 	if (chan->load_state == S3C2410_DMALOAD_1LOADED) {
BtrLinux
Privacy Overview
