ARM: rockchip: pm: Fix PTR_ERR() argument
Author: Fabio Estevam <fabio.estevam@freescale.com>
PTR_ERR should access the value just tested by IS_ERR.
The semantic patch that makes this change is available
in scripts/coccinelle/tests/odd_ptr_err.cocci.
Signed-off-by: Fabio Estevam
Reviewed-by: Matthias Brugger
Signed-off-by: Heiko Stuebner
 arch/arm/mach-rockchip/pm.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-rockchip/pm.c b/arch/arm/mach-rockchip/pm.c
index 156cd23..bee8c80 100644
--- a/arch/arm/mach-rockchip/pm.c
+++ b/arch/arm/mach-rockchip/pm.c
@@ -246,14 +246,14 @@ static int rk3288_suspend_init(struct device_node *np)
 				"rockchip,rk3288-sgrf");
 	if (IS_ERR(sgrf_regmap)) {
 		pr_err("%s: could not find sgrf regmap\n", __func__);
-		return PTR_ERR(pmu_regmap);
+		return PTR_ERR(sgrf_regmap);
 	grf_regmap = syscon_regmap_lookup_by_compatible(
 				"rockchip,rk3288-grf");
 	if (IS_ERR(grf_regmap)) {
 		pr_err("%s: could not find grf regmap\n", __func__);
+		return PTR_ERR(grf_regmap);
 	sram_np = of_find_compatible_node(NULL, NULL,
