arm: Reorder irq_set_ function calls
Author: Thomas Gleixner <tglx@linutronix.de>
Reorder
irq_set_chip()
irq_set_chip_data()
irq_set_handler()
to
irq_set_chip()
irq_set_handler()
irq_set_chip_data()
so the next patch can combine irq_set_chip() and irq_set_handler() to
irq_set_chip_and_handler().
Automated conversion with coccinelle.
Signed-off-by: Thomas Gleixner
 arch/arm/common/gic.c                | 2 +-
 arch/arm/common/locomo.c             | 2 +-
 arch/arm/common/sa1111.c             | 4 ++--
 arch/arm/common/vic.c                | 2 +-
 arch/arm/mach-exynos4/irq-combiner.c | 2 +-
 arch/arm/mach-pxa/irq.c              | 4 ++--
 arch/arm/mach-s3c64xx/irq-eint.c     | 2 +-
 arch/arm/plat-orion/irq.c            | 2 +-
 arch/arm/plat-samsung/irq-uart.c     | 2 +-
 9 files changed, 11 insertions(+), 11 deletions(-)
diff --git a/arch/arm/common/gic.c b/arch/arm/common/gic.c
index 50d5b20..630d46b 100644
--- a/arch/arm/common/gic.c
+++ b/arch/arm/common/gic.c
@@ -320,8 +320,8 @@ static void __init gic_dist_init(struct gic_chip_data *gic,
 	for (i = irq_start; i < irq_limit; i++) {
 		irq_set_chip(i, &gic_chip);
-		irq_set_chip_data(i, gic);
 		irq_set_handler(i, handle_level_irq);
+		irq_set_chip_data(i, gic);
 		set_irq_flags(i, IRQF_VALID | IRQF_PROBE);
diff --git a/arch/arm/common/locomo.c b/arch/arm/common/locomo.c
index ea18b35..54d91f8 100644
--- a/arch/arm/common/locomo.c
+++ b/arch/arm/common/locomo.c
@@ -204,8 +204,8 @@ static void locomo_setup_irq(struct locomo *lchip)
 	/* Install handlers for IRQ_LOCOMO_* */
 	for ( ; irq <= lchip->irq_base + 3; irq++) {
 		irq_set_chip(irq, &locomo_chip);
-		irq_set_chip_data(irq, lchip);
 		irq_set_handler(irq, handle_level_irq);
+		irq_set_chip_data(irq, lchip);
 		set_irq_flags(irq, IRQF_VALID | IRQF_PROBE);
diff --git a/arch/arm/common/sa1111.c b/arch/arm/common/sa1111.c
index 11ab3c2..f098f5c 100644
--- a/arch/arm/common/sa1111.c
+++ b/arch/arm/common/sa1111.c
@@ -473,15 +473,15 @@ static void sa1111_setup_irq(struct sa1111 *sachip)
 	for (irq = IRQ_GPAIN0; irq <= SSPROR; irq++) {
 		irq_set_chip(irq, &sa1111_low_chip);
-		irq_set_chip_data(irq, sachip);
 		irq_set_handler(irq, handle_edge_irq);
+		irq_set_chip_data(irq, sachip);
 	for (irq = AUDXMTDMADONEA; irq <= IRQ_S1_BVD1_STSCHG; irq++) {
 		irq_set_chip(irq, &sa1111_high_chip);
diff --git a/arch/arm/common/vic.c b/arch/arm/common/vic.c
index 297078b..e282fd1 100644
--- a/arch/arm/common/vic.c
+++ b/arch/arm/common/vic.c
@@ -306,8 +306,8 @@ static void __init vic_set_irq_sources(void __iomem *base,
 			unsigned int irq = irq_start + i;
 			irq_set_chip(irq, &vic_chip);
-			irq_set_chip_data(irq, base);
+			irq_set_chip_data(irq, base);
diff --git a/arch/arm/mach-exynos4/irq-combiner.c b/arch/arm/mach-exynos4/irq-combiner.c
index 0c18080..3a217be 100644
--- a/arch/arm/mach-exynos4/irq-combiner.c
+++ b/arch/arm/mach-exynos4/irq-combiner.c
@@ -120,8 +120,8 @@ void __init combiner_init(unsigned int combiner_nr, void __iomem *base,
 	for (i = irq_start; i < combiner_data[combiner_nr].irq_offset
 				+ MAX_IRQ_IN_COMBINER; i++) {
 		irq_set_chip(i, &combiner_chip);
-		irq_set_chip_data(i, &combiner_data[combiner_nr]);
+		irq_set_chip_data(i, &combiner_data[combiner_nr]);
diff --git a/arch/arm/mach-pxa/irq.c b/arch/arm/mach-pxa/irq.c
index cc7bfc3..70344cc 100644
--- a/arch/arm/mach-pxa/irq.c
+++ b/arch/arm/mach-pxa/irq.c
@@ -138,8 +138,8 @@ static void __init pxa_init_low_gpio_irq(set_wake_t fn)
 	for (irq = IRQ_GPIO0; irq <= IRQ_GPIO1; irq++) {
 		irq_set_chip(irq, &pxa_low_gpio_chip);
-		irq_set_chip_data(irq, irq_base(0));
+		irq_set_chip_data(irq, irq_base(0));
 		set_irq_flags(irq, IRQF_VALID);
@@ -166,8 +166,8 @@ void __init pxa_init_irq(int irq_nr, set_wake_t fn)
 			irq = PXA_IRQ(i);
 			irq_set_chip(irq, &pxa_internal_irq_chip);
diff --git a/arch/arm/mach-s3c64xx/irq-eint.c b/arch/arm/mach-s3c64xx/irq-eint.c
index 9a4c7ae..6d70348 100644
--- a/arch/arm/mach-s3c64xx/irq-eint.c
+++ b/arch/arm/mach-s3c64xx/irq-eint.c
@@ -198,8 +198,8 @@ static int __init s3c64xx_init_irq_eint(void)
 	for (irq = IRQ_EINT(0); irq <= IRQ_EINT(27); irq++) {
 		irq_set_chip(irq, &s3c_irq_eint);
-		irq_set_chip_data(irq, (void *)eint_irq_to_bit(irq));
+		irq_set_chip_data(irq, (void *)eint_irq_to_bit(irq));
diff --git a/arch/arm/plat-orion/irq.c b/arch/arm/plat-orion/irq.c
index aba3ffe..f533bde 100644
--- a/arch/arm/plat-orion/irq.c
+++ b/arch/arm/plat-orion/irq.c
@@ -57,8 +57,8 @@ void __init orion_irq_init(unsigned int irq_start, void __iomem *maskaddr)
 		irq_set_chip(irq, &orion_irq_chip);
-		irq_set_chip_data(irq, maskaddr);
+		irq_set_chip_data(irq, maskaddr);
 		irq_set_status_flags(irq, IRQ_LEVEL);
diff --git a/arch/arm/plat-samsung/irq-uart.c b/arch/arm/plat-samsung/irq-uart.c
index 3c064a0..9dbad70 100644
--- a/arch/arm/plat-samsung/irq-uart.c
+++ b/arch/arm/plat-samsung/irq-uart.c
@@ -118,8 +118,8 @@ static void __init s3c_init_uart_irq(struct s3c_uart_irq *uirq)
 		irq = uirq->base_irq + offs;
 		irq_set_chip(irq, &s3c_irq_uart);
-		irq_set_chip_data(irq, uirq);
+		irq_set_chip_data(irq, uirq);
BtrLinux
Privacy Overview
