ARM: pxa: Use setup_timer
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use the timer API function setup_timer instead of structure field
assignments to initialize a timer.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@change@
expression e1, e2, a;
-init_timer(&e1);
+setup_timer(&e1, a, 0UL);
... when != a = e2
-e1.function = a;
Signed-off-by: Vaishali Thakkar
Signed-off-by: Robert Jarzmik
arch/arm/mach-pxa/sharpsl_pm.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
diff --git a/arch/arm/mach-pxa/sharpsl_pm.c b/arch/arm/mach-pxa/sharpsl_pm.c
index 051a655..bdc0c41 100644
--- a/arch/arm/mach-pxa/sharpsl_pm.c
+++ b/arch/arm/mach-pxa/sharpsl_pm.c
@@ -841,11 +841,9 @@ static int sharpsl_pm_probe(struct platform_device *pdev)
sharpsl_pm.charge_mode = CHRG_OFF;
sharpsl_pm.flags = 0;
- init_timer(&sharpsl_pm.ac_timer);
- sharpsl_pm.ac_timer.function = sharpsl_ac_timer;
+ setup_timer(&sharpsl_pm.ac_timer, sharpsl_ac_timer, 0UL);
- init_timer(&sharpsl_pm.chrg_full_timer);
- sharpsl_pm.chrg_full_timer.function = sharpsl_chrg_full_timer;
+ setup_timer(&sharpsl_pm.chrg_full_timer, sharpsl_chrg_full_timer, 0UL);
led_trigger_register_simple("sharpsl-charge", &sharpsl_charge_led_trigger); |
