ARM: OMAP2: Delete an unnecessary check
Author: Markus Elfring <elfring@users.sourceforge.net>
The of_node_put() function tests whether its argument is NULL and then
returns immediately if so.  Furthermore, the kerneldoc for
of_node_put() explicitly supports passing in a NULL pointer as its
argument.  Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
[paul@pwsan.com: dropped the omap_device.c and omap_hwmod.c changes for
 now, edited the commit message accordingly and to note the documented
 "contract"]
Reviewed-by: Paul Walmsley
Signed-off-by: Paul Walmsley
 arch/arm/mach-omap2/timer.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-omap2/timer.c b/arch/arm/mach-omap2/timer.c
index cac46d8..15448221 100644
--- a/arch/arm/mach-omap2/timer.c
+++ b/arch/arm/mach-omap2/timer.c
@@ -208,8 +208,7 @@ static void __init omap_dmtimer_init(void)
 	/* If we are a secure device, remove any secure timer nodes */
 	if ((omap_type() != OMAP2_DEVICE_TYPE_GP)) {
 		np = omap_get_timer_dt(omap_timer_match, "ti,timer-secure");
-		if (np)
-			of_node_put(np);
+		of_node_put(np);
BtrLinux
Privacy Overview
