ARM: OMAP1: use BUG_ON where possible
Author: Sasha Levin <sasha.levin@oracle.com>
Just use BUG_ON() instead of constructions such as:
	if (...)
		BUG()
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
expression e;
- if (e) BUG();
+ BUG_ON(e);
Signed-off-by: Sasha Levin
Signed-off-by: Tony Lindgren
 arch/arm/mach-omap1/board-fsample.c  | 3 +--
 arch/arm/mach-omap1/board-h2.c       | 3 +--
 arch/arm/mach-omap1/board-h3.c       | 3 +--
 arch/arm/mach-omap1/board-perseus2.c | 3 +--
 4 files changed, 4 insertions(+), 8 deletions(-)
diff --git a/arch/arm/mach-omap1/board-fsample.c b/arch/arm/mach-omap1/board-fsample.c
index 4b6de70..756872e 100644
--- a/arch/arm/mach-omap1/board-fsample.c
+++ b/arch/arm/mach-omap1/board-fsample.c
@@ -307,8 +307,7 @@ static void __init omap_fsample_init(void)
 	fsample_init_smc91x();
-	if (gpio_request(FSAMPLE_NAND_RB_GPIO_PIN, "NAND ready") < 0)
-		BUG();
+	BUG_ON(gpio_request(FSAMPLE_NAND_RB_GPIO_PIN, "NAND ready") < 0);
 	gpio_direction_input(FSAMPLE_NAND_RB_GPIO_PIN);
 	omap_cfg_reg(L3_1610_FLASH_CS2B_OE);
diff --git a/arch/arm/mach-omap1/board-h2.c b/arch/arm/mach-omap1/board-h2.c
index 376f7f2..9d533ee 100644
--- a/arch/arm/mach-omap1/board-h2.c
+++ b/arch/arm/mach-omap1/board-h2.c
@@ -411,8 +411,7 @@ static void __init h2_init(void)
 	h2_nand_resource.end = h2_nand_resource.start = OMAP_CS2B_PHYS;
 	h2_nand_resource.end += SZ_4K - 1;
-	if (gpio_request(H2_NAND_RB_GPIO_PIN, "NAND ready") < 0)
-		BUG();
+	BUG_ON(gpio_request(H2_NAND_RB_GPIO_PIN, "NAND ready") < 0);
 	gpio_direction_input(H2_NAND_RB_GPIO_PIN);
diff --git a/arch/arm/mach-omap1/board-h3.c b/arch/arm/mach-omap1/board-h3.c
index ededdb7..be60862 100644
--- a/arch/arm/mach-omap1/board-h3.c
+++ b/arch/arm/mach-omap1/board-h3.c
@@ -406,8 +406,7 @@ static void __init h3_init(void)
 	nand_resource.end = nand_resource.start = OMAP_CS2B_PHYS;
-	if (gpio_request(H3_NAND_RB_GPIO_PIN, "NAND ready") < 0)
-		BUG();
+	BUG_ON(gpio_request(H3_NAND_RB_GPIO_PIN, "NAND ready") < 0);
 	gpio_direction_input(H3_NAND_RB_GPIO_PIN);
 	/* GPIO10 Func_MUX_CTRL reg bit 29:27, Configure V2 to mode1 as GPIO */
diff --git a/arch/arm/mach-omap1/board-perseus2.c b/arch/arm/mach-omap1/board-perseus2.c
index 198b054..327ffcf 100644
--- a/arch/arm/mach-omap1/board-perseus2.c
+++ b/arch/arm/mach-omap1/board-perseus2.c
@@ -275,8 +275,7 @@ static void __init omap_perseus2_init(void)
 	perseus2_init_smc91x();
-	if (gpio_request(P2_NAND_RB_GPIO_PIN, "NAND ready") < 0)
-		BUG();
+	BUG_ON(gpio_request(P2_NAND_RB_GPIO_PIN, "NAND ready") < 0);
 	gpio_direction_input(P2_NAND_RB_GPIO_PIN);
BtrLinux
Privacy Overview
