arm: mach-davinci: check irq2ctlr() result
Author: Kulikov Vasiliy <segooon@gmail.com>
If irq2ctlr() fails return IRQ_NONE.
Also as it can fail make 'ctlr' signed.
The semantic patch that finds this problem (many false-positive results):
(http://coccinelle.lip6.fr/)
@ r1 @
identifier f;
int f(...) { ... }
identifier r1.f;
type T;
unsigned T x;
*x = f(...)
*x > 0
Signed-off-by: Kulikov Vasiliy
Signed-off-by: Kevin Hilman
 arch/arm/mach-davinci/dma.c | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-davinci/dma.c b/arch/arm/mach-davinci/dma.c
index 2ede598..6b96698 100644
--- a/arch/arm/mach-davinci/dma.c
+++ b/arch/arm/mach-davinci/dma.c
@@ -354,10 +354,12 @@ static int irq2ctlr(int irq)
 static irqreturn_t dma_irq_handler(int irq, void *data)
 	int i;
-	unsigned ctlr;
+	int ctlr;
 	unsigned int cnt = 0;
 	ctlr = irq2ctlr(irq);
+	if (ctlr < 0)
+		return IRQ_NONE;
 	dev_dbg(data, "dma_irq_handler\n");
@@ -408,10 +410,12 @@ static irqreturn_t dma_irq_handler(int irq, void *data)
 static irqreturn_t dma_ccerr_handler(int irq, void *data)
 	int i;
-	unsigned ctlr;
+	int ctlr;
+	if (ctlr < 0)
+		return IRQ_NONE;
 	dev_dbg(data, "dma_ccerr_handler\n");
BtrLinux
Privacy Overview
