ARM: integrator: use BUG_ON where possible
Author: Sasha Levin <sasha.levin@oracle.com>
Just use BUG_ON() instead of constructions such as:
	if (...)
		BUG()
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
expression e;
- if (e) BUG();
+ BUG_ON(e);
Signed-off-by: Sasha Levin
Acked-by: Arnd Bergmann
Signed-off-by: Linus Walleij
 arch/arm/mach-integrator/pci_v3.c | 9 +++------
 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/arch/arm/mach-integrator/pci_v3.c b/arch/arm/mach-integrator/pci_v3.c
index 000edcd..be50e79 100644
--- a/arch/arm/mach-integrator/pci_v3.c
+++ b/arch/arm/mach-integrator/pci_v3.c
@@ -191,12 +191,9 @@ static void __iomem *v3_open_config_window(struct pci_bus *bus,
 	 * Trap out illegal values
-	if (offset > 255)
-		BUG();
-	if (busnr > 255)
-		BUG();
-	if (devfn > 255)
-		BUG();
+	BUG_ON(offset > 255);
+	BUG_ON(busnr > 255);
+	BUG_ON(devfn > 255);
 	if (busnr == 0) {
 		int slot = PCI_SLOT(devfn);
BtrLinux
Privacy Overview
