ARM: davinci: dm644x evm: move pointer dereference below NULL check
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
Pointer dereference should be moved below the NULL test.
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Sekhar Nori
arch/arm/mach-davinci/board-dm644x-evm.c | 5 +++--
1 file changed, 3 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-davinci/board-dm644x-evm.c b/arch/arm/mach-davinci/board-dm644x-evm.c
index f22572ce..f8a99ee 100644
--- a/arch/arm/mach-davinci/board-dm644x-evm.c
+++ b/arch/arm/mach-davinci/board-dm644x-evm.c
@@ -519,13 +519,11 @@ static int dm6444evm_msp430_get_pins(void)
char buf[4];
struct i2c_msg msg[2] = {
- .addr = dm6446evm_msp->addr,
.flags = 0,
.len = 2,
.buf = (void __force *)txbuf,
.flags = I2C_M_RD,
.len = 4,
.buf = buf,
@@ -536,6 +534,9 @@ static int dm6444evm_msp430_get_pins(void)
if (!dm6446evm_msp)
return -ENXIO;
+ msg[0].addr = dm6446evm_msp->addr;
+ msg[1].addr = dm6446evm_msp->addr;
/* Command 4 == get input state, returns port 2 and port3 data
* S Addr W [A] len=2 [A] cmd=4 [A]
* RS Addr R [A] [len=4] A [cmd=4] A [port2] A [port3] N P |
char buf[4];
.flags = 0,
.len = 2,
.flags = I2C_M_RD,
.len = 4,
.buf = buf,
if (!dm6446evm_msp)
return -ENXIO;
