arm-cci: fix handling cpumask_any_but return value
Author: Andrzej Hajda <a.hajda@samsung.com>
cpumask_any_but returns value >= nr_cpu_ids if there are no more CPUs.
The problem has been detected using proposed semantic patch
scripts/coccinelle/tests/unsigned_lesser_than_zero.cocci [1].
[1]: http://permalink.gmane.org/gmane.linux.kernel/2038576
Acked-by: Olof Johansson
Signed-off-by: Andrzej Hajda
Acked-by: Will Deacon
Signed-off-by: Suzuki K Poulose
Signed-off-by: Will Deacon
 drivers/bus/arm-cci.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/bus/arm-cci.c b/drivers/bus/arm-cci.c
index ee47e6b..5fb1c06 100644
--- a/drivers/bus/arm-cci.c
+++ b/drivers/bus/arm-cci.c
@@ -1270,7 +1270,7 @@ static int cci_pmu_cpu_notifier(struct notifier_block *self,
 		if (!cpumask_test_and_clear_cpu(cpu, &cci_pmu->cpus))
 			break;
 		target = cpumask_any_but(cpu_online_mask, cpu);
-		if (target < 0) // UP, last CPU
+		if (target >= nr_cpu_ids) // UP, last CPU
 			break;
 		 * TODO: migrate context once core races on event->ctx have
BtrLinux
Privacy Overview
