ARM: 5635/1: Use DIV_ROUND_CLOSEST
The kernel.h macro DIV_ROUND_CLOSEST performs the computation
(x + d/2)/d but is perhaps more readable.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
Signed-off-by: Julia Lawall
Acked-by: H Hartley Sweeten
Signed-off-by: Russell King
 arch/arm/mach-ep93xx/core.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/mach-ep93xx/core.c b/arch/arm/mach-ep93xx/core.c
index 4075529..16b92c3 100644
--- a/arch/arm/mach-ep93xx/core.c
+++ b/arch/arm/mach-ep93xx/core.c
@@ -82,7 +82,7 @@ void __init ep93xx_map_io(void)
 static unsigned int last_jiffy_time;
-#define TIMER4_TICKS_PER_JIFFY		((CLOCK_TICK_RATE + (HZ/2)) / HZ)
+#define TIMER4_TICKS_PER_JIFFY		DIV_ROUND_CLOSEST(CLOCK_TICK_RATE, HZ)
 static irqreturn_t ep93xx_timer_interrupt(int irq, void *dev_id)
BtrLinux
Privacy Overview
