arch/x86/kernel/pci-calgary_64.c: change simple_strtol to simple_strtoul
Impact: fix theoretical option string parsing overflow
Since bridge is unsigned, it would seem better to use simple_strtoul that
simple_strtol.
A simplified version of the semantic patch that makes this change is as
follows: (http://www.emn.fr/x-info/coccinelle/)
@r2@
long e;
position p;
e = simple_strtol@p(...)
position p != r2.p;
type T;
T e;
e =
- simple_strtol@p
+ simple_strtoul
Signed-off-by: Julia Lawall
Cc: muli@il.ibm.com
Cc: jdmason@kudzu.us
Cc: discuss@x86-64.org
Signed-off-by: Ingo Molnar
 arch/x86/kernel/pci-calgary_64.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/x86/kernel/pci-calgary_64.c b/arch/x86/kernel/pci-calgary_64.c
index e1e731d..d28bbdc 100644
--- a/arch/x86/kernel/pci-calgary_64.c
+++ b/arch/x86/kernel/pci-calgary_64.c
@@ -1567,7 +1567,7 @@ static int __init calgary_parse_options(char *p)
 				++p;
 			if (*p == '\0')
 				break;
-			bridge = simple_strtol(p, &endp, 0);
+			bridge = simple_strtoul(p, &endp, 0);
 			if (p == endp)
 				break;
BtrLinux
Privacy Overview
