arch/x86/kernel/kdebugfs.c: Ensure a consistent return value in error case
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Typically, the return value desired for the failure of a
function with an integer return value is a negative integer.  In
these cases, the return value is sometimes a negative integer
and sometimes 0, due to a subsequent initialization of the
return variable within the loop.
A simplified version of the semantic match that finds this
problem is: (http://coccinelle.lip6.fr/)
@r exists@
identifier ret;
position p;
constant C;
expression e1,e3,e4;
statement S;
ret = -C
... when != ret = e3
    when any
if@p (...) S
... when any
if (\(ret != 0\|ret < 0\|ret > 0\) || ...) { ... return ...; }
    when any
*if@p (...)
  ... when != ret = e4
  return ret;
Signed-off-by: Julia Lawall
Link: http://lkml.kernel.org/r/1342284188-19176-7-git-send-email-Julia.Lawall@lip6.fr
Signed-off-by: Ingo Molnar
 arch/x86/kernel/kdebugfs.c | 6 ++++--
 1 file changed, 4 insertions(+), 2 deletions(-)
diff --git a/arch/x86/kernel/kdebugfs.c b/arch/x86/kernel/kdebugfs.c
index 1d5d31e..dc1404b 100644
--- a/arch/x86/kernel/kdebugfs.c
+++ b/arch/x86/kernel/kdebugfs.c
@@ -107,7 +107,7 @@ static int __init create_setup_data_nodes(struct dentry *parent)
 	struct setup_data_node *node;
 	struct setup_data *data;
-	int error = -ENOMEM;
+	int error;
 	struct dentry *d;
 	struct page *pg;
 	u64 pa_data;
@@ -121,8 +121,10 @@ static int __init create_setup_data_nodes(struct dentry *parent)
 	while (pa_data) {
 		node = kmalloc(sizeof(*node), GFP_KERNEL);
-		if (!node)
+		if (!node) {
+			error = -ENOMEM;
 			goto err_dir;
 		pg = pfn_to_page((pa_data+sizeof(*data)-1) >> PAGE_SHIFT);
 		if (PageHighMem(pg)) {
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
