arch/x86: Remove unecessary semicolons
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Found by http://coccinelle.lip6.fr/
Signed-off-by: Peter Senna Tschudin
Cc: avi@redhat.com
Cc: mtosatti@redhat.com
Cc: a.p.zijlstra@chello.nl
Cc: rusty@rustcorp.com.au
Cc: masami.hiramatsu.pt@hitachi.com
Cc: suresh.b.siddha@intel.com
Cc: joerg.roedel@amd.com
Cc: agordeev@redhat.com
Cc: yinghai@kernel.org
Cc: bhelgaas@google.com
Cc: liuj97@gmail.com
Link: http://lkml.kernel.org/r/1347986174-30287-7-git-send-email-peter.senna@gmail.com
Signed-off-by: Ingo Molnar
 arch/x86/kernel/alternative.c  | 4 ++--
 arch/x86/kernel/apic/apic.c    | 2 +-
 arch/x86/kvm/vmx.c             | 2 +-
 arch/x86/pci/mmconfig-shared.c | 2 +-
 4 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/arch/x86/kernel/alternative.c b/arch/x86/kernel/alternative.c
index ced4534..3318b1e 100644
--- a/arch/x86/kernel/alternative.c
+++ b/arch/x86/kernel/alternative.c
@@ -317,7 +317,7 @@ static void alternatives_smp_lock(const s32 *start, const s32 *end,
 		/* turn DS segment override prefix into lock prefix */
 		if (*ptr == 0x3e)
 			text_poke(ptr, ((unsigned char []){0xf0}), 1);
 	mutex_unlock(&text_mutex);
@@ -338,7 +338,7 @@ static void alternatives_smp_unlock(const s32 *start, const s32 *end,
 		/* turn lock prefix into DS segment override prefix */
 		if (*ptr == 0xf0)
 			text_poke(ptr, ((unsigned char []){0x3E}), 1);
diff --git a/arch/x86/kernel/apic/apic.c b/arch/x86/kernel/apic/apic.c
index 24deb30..b17416e 100644
--- a/arch/x86/kernel/apic/apic.c
+++ b/arch/x86/kernel/apic/apic.c
@@ -1934,7 +1934,7 @@ void smp_error_interrupt(struct pt_regs *regs)
 			apic_printk(APIC_DEBUG, KERN_CONT " : %s", error_interrupt_reason[i]);
 		i++;
 		v1 >>= 1;
 	apic_printk(APIC_DEBUG, KERN_CONT "\n");
diff --git a/arch/x86/kvm/vmx.c b/arch/x86/kvm/vmx.c
index b1eb202..b06737d 100644
--- a/arch/x86/kvm/vmx.c
+++ b/arch/x86/kvm/vmx.c
@@ -4543,7 +4543,7 @@ static int handle_cr(struct kvm_vcpu *vcpu)
 				vcpu->run->exit_reason = KVM_EXIT_SET_TPR;
 				return 0;
 		break;
 	case 2: /* clts */
 		handle_clts(vcpu);
diff --git a/arch/x86/pci/mmconfig-shared.c b/arch/x86/pci/mmconfig-shared.c
index 937bcec..704b9ec 100644
--- a/arch/x86/pci/mmconfig-shared.c
+++ b/arch/x86/pci/mmconfig-shared.c
@@ -585,7 +585,7 @@ static int __init pci_parse_mcfg(struct acpi_table_header *header)
 	while (i >= sizeof(struct acpi_mcfg_allocation)) {
 		entries++;
 		i -= sizeof(struct acpi_mcfg_allocation);
 	if (entries == 0) {
 		pr_err(PREFIX "MMCONFIG has no entries\n");
 		return -ENODEV;
BtrLinux
Privacy Overview
