arch/um/drivers: remove duplicate structure field initialization
There are two initializations of ndo_set_mac_address, one to a local
function that is not used otherwise and one to a function that is defined
elsewhere.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
@r@
identifier I, s, fld;
position p0,p;
expression E;
struct I s =@p0 { ... .fld@p = E, ...};
@s@
identifier I, s, r.fld;
position r.p0,p;
expression E;
@script:python@
p0 << r.p0;
fld << r.fld;
ps << s.p;
pr << r.p;
if int(ps[0].line)
akpm:
- Use the standard eth_mac_addr() in uml_net_set_mac()
- Remove unneeded and racy local set_ether_mac()
- Remove duplicated (and incorrect)
  uml_netdev_ops.ndo_set_mac_address initializer.
Fixes 8bb95b39a16ed55226810596f92216c53329d2fe ("uml: convert network
device to netdevice ops").
[akpm@linux-foundation.org: rework as above]
Signed-off-by: Julia Lawall
Cc: Stephen Hemminger
Cc: "David S. Miller"
Signed-off-by: Andrew Morton
Signed-off-by: David S. Miller
 arch/um/drivers/net_kern.c | 10 ++--------
 1 file changed, 2 insertions(+), 8 deletions(-)
diff --git a/arch/um/drivers/net_kern.c b/arch/um/drivers/net_kern.c
index f053726..2ab233b 100644
--- a/arch/um/drivers/net_kern.c
+++ b/arch/um/drivers/net_kern.c
@@ -25,11 +25,6 @@
 #include "net_kern.h"
 #include "net_user.h"
-static inline void set_ether_mac(struct net_device *dev, unsigned char *addr)
-	memcpy(dev->dev_addr, addr, ETH_ALEN);
 #define DRIVER_NAME "uml-netdev"
 static DEFINE_SPINLOCK(opened_lock);
@@ -266,7 +261,7 @@ static int uml_net_set_mac(struct net_device *dev, void *addr)
 	struct sockaddr *hwaddr = addr;
 	spin_lock_irq(&lp->lock);
-	set_ether_mac(dev, hwaddr->sa_data);
+	eth_mac_addr(dev, hwaddr->sa_data);
 	spin_unlock_irq(&lp->lock);
 	return 0;
@@ -380,7 +375,6 @@ static const struct net_device_ops uml_netdev_ops = {
 	.ndo_tx_timeout 	= uml_net_tx_timeout,
 	.ndo_set_mac_address	= uml_net_set_mac,
 	.ndo_change_mtu 	= uml_net_change_mtu,
-	.ndo_set_mac_address 	= eth_mac_addr,
 	.ndo_validate_addr	= eth_validate_addr,
@@ -478,7 +472,7 @@ static void eth_configure(int n, void *init, char *mac,
 	    ((*transport->user->init)(&lp->user, dev) != 0))
 		goto out_unregister;
-	set_ether_mac(dev, device->mac);
+	eth_mac_addr(dev, device->mac);
 	dev->mtu = transport->user->mtu;
 	dev->netdev_ops = &uml_netdev_ops;
 	dev->ethtool_ops = &uml_net_ethtool_ops;
BtrLinux
Privacy Overview
