arch/sparc/kernel/sysfs.c | 4 ++--
arch/sparc/kernel/us2e_cpufreq.c | 8 ++++----
arch/sparc/kernel/us3_cpufreq.c | 8 ++++----
3 files changed, 10 insertions(+), 10 deletions(-)
diff --git a/arch/sparc/kernel/sysfs.c b/arch/sparc/kernel/sysfs.c
index ca39c60..1eb8b00 100644
--- a/arch/sparc/kernel/sysfs.c
+++ b/arch/sparc/kernel/sysfs.c
@@ -107,12 +107,12 @@ static unsigned long run_on_cpu(unsigned long cpu,
unsigned long ret;
/* should return -EINVAL to userspace */
- if (set_cpus_allowed(current, cpumask_of_cpu(cpu)))
+ if (set_cpus_allowed_ptr(current, cpumask_of(cpu)))
return 0;
ret = func(arg);
- set_cpus_allowed(current, old_affinity);
+ set_cpus_allowed_ptr(current, &old_affinity);
return ret;
diff --git a/arch/sparc/kernel/us2e_cpufreq.c b/arch/sparc/kernel/us2e_cpufreq.c
index 791c151..8f982b7 100644
--- a/arch/sparc/kernel/us2e_cpufreq.c
+++ b/arch/sparc/kernel/us2e_cpufreq.c
@@ -238,12 +238,12 @@ static unsigned int us2e_freq_get(unsigned int cpu)
return 0;
cpus_allowed = current->cpus_allowed;
- set_cpus_allowed(current, cpumask_of_cpu(cpu));
+ set_cpus_allowed_ptr(current, cpumask_of(cpu));
clock_tick = sparc64_get_clock_tick(cpu) / 1000;
estar = read_hbreg(HBIRD_ESTAR_MODE_ADDR);
- set_cpus_allowed(current, cpus_allowed);
+ set_cpus_allowed_ptr(current, &cpus_allowed);
return clock_tick / estar_to_divisor(estar);
@@ -259,7 +259,7 @@ static void us2e_set_cpu_divider_index(unsigned int cpu, unsigned int index)
return;
new_freq = clock_tick = sparc64_get_clock_tick(cpu) / 1000;
new_bits = index_to_estar_mode(index);
@@ -281,7 +281,7 @@ static void us2e_set_cpu_divider_index(unsigned int cpu, unsigned int index)
cpufreq_notify_transition(&freqs, CPUFREQ_POSTCHANGE);
static int us2e_freq_target(struct cpufreq_policy *policy,
diff --git a/arch/sparc/kernel/us3_cpufreq.c b/arch/sparc/kernel/us3_cpufreq.c
index 365b646..f35d1e7 100644
--- a/arch/sparc/kernel/us3_cpufreq.c
+++ b/arch/sparc/kernel/us3_cpufreq.c
@@ -86,12 +86,12 @@ static unsigned int us3_freq_get(unsigned int cpu)
return 0;
reg = read_safari_cfg();
ret = get_current_freq(cpu, reg);
return ret;
@@ -106,7 +106,7 @@ static void us3_set_cpu_divider_index(unsigned int cpu, unsigned int index)
return;
new_freq = sparc64_get_clock_tick(cpu) / 1000;
switch (index) {
@@ -140,7 +140,7 @@ static void us3_set_cpu_divider_index(unsigned int cpu, unsigned int index)
static int us3_freq_target(struct cpufreq_policy *policy, |
