arch/sh/mm: Move a dereference below a NULL test
If the NULL test is necessary, then the dereference should be moved below
the NULL test.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/).
@disable is_null@
identifier f;
expression E;
identifier fld;
statement S;
+ if (E == NULL) S
  f(...,E->fld,...);
- if (E == NULL) S
identifier f;
expression E;
identifier fld;
statement S;
+ if (!E) S
  f(...,E->fld,...);
- if (!E) S
Signed-off-by: Julia Lawall
Signed-off-by: Paul Mundt
 arch/sh/mm/ioremap_64.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/sh/mm/ioremap_64.c b/arch/sh/mm/ioremap_64.c
index 6e0be24..31e1bb5 100644
--- a/arch/sh/mm/ioremap_64.c
+++ b/arch/sh/mm/ioremap_64.c
@@ -71,9 +71,9 @@ void *__ioremap(unsigned long phys_addr, unsigned long size,
 	 * Ok, go for it..
 	area = get_vm_area(size, VM_IOREMAP);
-	pr_debug("Get vm_area returns %p addr %p\n",area,area->addr);
 	if (!area)
 		return NULL;
+	pr_debug("Get vm_area returns %p addr %p\n", area, area->addr);
 	area->phys_addr = phys_addr;
 	addr = area->addr;
 	if (ioremap_page_range((unsigned long)addr, (unsigned long)addr + size,
BtrLinux
Privacy Overview
