arch/sh/mm: Eliminate a double lock
The function begins and ends with a read_lock.  The latter is changed to a
read_unlock.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@locked@
expression E1;
position p;
read_lock(E1@p,...);
@r exists@
expression x <= locked.E1;
expression locked.E1;
expression E2;
identifier lock;
position locked.p,p1,p2;
*lock@p1 (E1@p,...);
... when != E1
    when != \(x = E2\|&x\)
*lock@p2 (E1,...);
Signed-off-by: Julia Lawall
Acked-by: Matt Fleming
Signed-off-by: Paul Mundt
 arch/sh/mm/pmb.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/sh/mm/pmb.c b/arch/sh/mm/pmb.c
index 18623ba..6379091 100644
--- a/arch/sh/mm/pmb.c
+++ b/arch/sh/mm/pmb.c
@@ -770,7 +770,7 @@ static void __init pmb_resize(void)
 		spin_unlock_irqrestore(&pmbe->lock, flags);
-	read_lock(&pmb_rwlock);
+	read_unlock(&pmb_rwlock);
 #endif
BtrLinux
Privacy Overview
