arch/powerpc/platforms/85xx/p1022_ds.c: adjust duplicate test
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete successive tests to the same location.  The code tested the result
of a previous call, that itself was already tested.  It is changed to test
the result of the most recent call.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
@s exists@
local idexpression y;
expression x,e;
*if ( \(x == NULL\|IS_ERR(x)\|y != 0\) )
 { ... when forall
   return ...; }
... when != \(y = e\|y += e\|y -= e\|y |= e\|y &= e\|y++\|y--\|&y\)
    when != \(XT_GETPAGE(...,y)\|WMI_CMD_BUF(...)\)
 { ... when forall
   return ...; }
Signed-off-by: Julia Lawall
Signed-off-by: Kumar Gala
 arch/powerpc/platforms/85xx/p1022_ds.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/powerpc/platforms/85xx/p1022_ds.c b/arch/powerpc/platforms/85xx/p1022_ds.c
index 7328b8d..29b6a2c 100644
--- a/arch/powerpc/platforms/85xx/p1022_ds.c
+++ b/arch/powerpc/platforms/85xx/p1022_ds.c
@@ -302,7 +302,7 @@ static void p1022ds_set_monitor_port(enum fsl_diu_monitor_port port)
 		goto exit;
 	cs1_addr = lbc_br_to_phys(ecm, num_laws, br1);
-	if (!cs0_addr) {
+	if (!cs1_addr) {
 		pr_err("p1022ds: could not determine physical address for CS1"
 		       " (BR1=%08x)\n", br1);
 		goto exit;
BtrLinux
Privacy Overview
