arch/powerpc/kvm/e500_tlb.c: fix error return code
Convert a 0 error return code to a negative one, as returned elsewhere in the
function.
A new label is also added to avoid freeing things that are known to not yet
be allocated.
A simplified version of the semantic match that finds the first problem is as
follows: (http://coccinelle.lip6.fr/)
identifier ret;
expression e,e1,e2,e3,e4,x;
if (\(ret != 0\|ret < 0\) || ...) { ... return ...; }
ret = 0
... when != ret = e1
*x = \(kmalloc\|kzalloc\|kcalloc\|devm_kzalloc\|ioremap\|ioremap_nocache\|devm_ioremap\|devm_ioremap_nocache\)(...);
... when != x = e2
    when != ret = e3
*if (x == NULL || ...)
  ... when != ret = e4
*  return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Alexander Graf
 arch/powerpc/kvm/e500_tlb.c | 19 +++++++++++++------
 1 file changed, 13 insertions(+), 6 deletions(-)
diff --git a/arch/powerpc/kvm/e500_tlb.c b/arch/powerpc/kvm/e500_tlb.c
index 641f978..c733894 100644
--- a/arch/powerpc/kvm/e500_tlb.c
+++ b/arch/powerpc/kvm/e500_tlb.c
@@ -1233,21 +1233,27 @@ int kvm_vcpu_ioctl_config_tlb(struct kvm_vcpu *vcpu,
 	virt = vmap(pages, num_pages, VM_MAP, PAGE_KERNEL);
-	if (!virt)
+	if (!virt) {
+		ret = -ENOMEM;
 		goto err_put_page;
 	privs[0] = kzalloc(sizeof(struct tlbe_priv) * params.tlb_sizes[0],
 			   GFP_KERNEL);
 	privs[1] = kzalloc(sizeof(struct tlbe_priv) * params.tlb_sizes[1],
 			   GFP_KERNEL);
-	if (!privs[0] || !privs[1])
-		goto err_put_page;
+	if (!privs[0] || !privs[1]) {
+		ret = -ENOMEM;
+		goto err_privs;
 	g2h_bitmap = kzalloc(sizeof(u64) * params.tlb_sizes[1],
 	                     GFP_KERNEL);
-	if (!g2h_bitmap)
+	if (!g2h_bitmap) {
+		ret = -ENOMEM;
+		goto err_privs;
 	free_gtlb(vcpu_e500);
@@ -1287,10 +1293,11 @@ int kvm_vcpu_ioctl_config_tlb(struct kvm_vcpu *vcpu,
 	kvmppc_recalc_tlb1map_range(vcpu_e500);
 	return 0;
-err_put_page:
+err_privs:
 	kfree(privs[0]);
 	kfree(privs[1]);
+err_put_page:
 	for (i = 0; i < num_pages; i++)
 		put_page(pages[i]);
BtrLinux
Privacy Overview
