arch/mn10300/mm: eliminate NULL dereference
dev_name always dereferences its argument, so it should not be called if
the argument is NULL.  The function indeed later tests the argument for
being NULL.
The semantic match that finds this problem is as follows:
(http://coccinelle.lip6.fr/)
  expression dev,E;
  *dev_name(dev)
  ... when != dev = E
  *dev == NULL
  *dev != NULL
Signed-off-by: Julia Lawall
Signed-off-by: David Howells
Signed-off-by: Linus Torvalds
 arch/mn10300/mm/dma-alloc.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/mn10300/mm/dma-alloc.c b/arch/mn10300/mm/dma-alloc.c
index 4e34880..159acb0 100644
--- a/arch/mn10300/mm/dma-alloc.c
+++ b/arch/mn10300/mm/dma-alloc.c
@@ -25,7 +25,8 @@ void *dma_alloc_coherent(struct device *dev, size_t size,
 	unsigned long addr;
 	void *ret;
-	printk("dma_alloc_coherent(%s,%zu,,%x)\n", dev_name(dev), size, gfp);
+	pr_debug("dma_alloc_coherent(%s,%zu,%x)\n",
+		 dev ? dev_name(dev) : "?", size, gfp);
 	if (0xbe000000 - pci_sram_allocated >= size) {
 		size = (size + 255) & ~255;
