arch/m68k/mm/motorola.c: Eliminate NULL test and memset after alloc_bootmem
As noted by Akinobu Mita in patch b1fceac2b9e04d278316b2faddf276015fc06e3b,
alloc_bootmem and related functions never return NULL and always return a
zeroed region of memory.  Thus a NULL test or memset after calls to these
functions is unnecessary.
This was fixed using the following semantic patch.
(http://www.emn.fr/x-info/coccinelle/)
expression E;
statement S;
E = \(alloc_bootmem\|alloc_bootmem_low\|alloc_bootmem_pages\|alloc_bootmem_low_pages\)(...)
.. when != E
- BUG_ON (E == NULL);
- if (E == NULL) S
expression E,E1;
.. when != E
- memset(E,0,E1);
Signed-off-by: Julia Lawall
Signed-off-by: Geert Uytterhoeven
Signed-off-by: Linus Torvalds
 arch/m68k/mm/motorola.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/arch/m68k/mm/motorola.c b/arch/m68k/mm/motorola.c
index 30d34f2..226795b 100644
--- a/arch/m68k/mm/motorola.c
+++ b/arch/m68k/mm/motorola.c
@@ -285,7 +285,6 @@ void __init paging_init(void)
 	 * to a couple of allocated pages
 	empty_zero_page = alloc_bootmem_pages(PAGE_SIZE);
-	memset(empty_zero_page, 0, PAGE_SIZE);
 	 * Set up SFC/DFC registers
BtrLinux
Privacy Overview
