arch/arm/plat-pxa/dma.c: correct NULL test
Test the just-allocated value for NULL rather than some other value.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression x,y;
statement S;
x = \(kmalloc\|kcalloc\|kzalloc\)(...);
if ((x) == NULL) S
if (
-   y
+   x
       == NULL)
 S
Signed-off-by: Julia Lawall
Cc: Eric Miao
Signed-off-by: Andrew Morton
Signed-off-by: Russell King
 arch/arm/plat-pxa/dma.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/plat-pxa/dma.c b/arch/arm/plat-pxa/dma.c
index 742350e..2d3c19d 100644
--- a/arch/arm/plat-pxa/dma.c
+++ b/arch/arm/plat-pxa/dma.c
@@ -245,7 +245,7 @@ static void pxa_dma_init_debugfs(void)
 	dbgfs_chan = kmalloc(sizeof(*dbgfs_state) * num_dma_channels,
 			     GFP_KERNEL);
-	if (!dbgfs_state)
+	if (!dbgfs_chan)
 		goto err_alloc;
 	chandir = debugfs_create_dir("channels", dbgfs_root);
BtrLinux
Privacy Overview
