arch/arm/plat-omap: Drop an unnecessary NULL test
map_iovm_area is only called from a context where its second argument is
known not to be NULL, so drop the unnecessary test.  If new could be NULL,
the initialization of da should be moved below the test.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
@match exists@
expression x, E;
identifier fld;
* x->fld
  ... when != \(x = E\|&x\)
* x == NULL
Signed-off-by: Julia Lawall
Cc: Russell King
Cc: Hiroshi DOYU
Signed-off-by: Tony Lindgren
Signed-off-by: Andrew Morton
 arch/arm/plat-omap/iovmm.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/plat-omap/iovmm.c b/arch/arm/plat-omap/iovmm.c
index 544772e..936aef1 100644
--- a/arch/arm/plat-omap/iovmm.c
+++ b/arch/arm/plat-omap/iovmm.c
@@ -446,7 +446,7 @@ static int map_iovm_area(struct iommu *obj, struct iovm_struct *new,
 	struct scatterlist *sg;
 	u32 da = new->da_start;
-	if (!obj || !new || !sgt)
+	if (!obj || !sgt)
 		return -EINVAL;
 	BUG_ON(!sgtable_ok(sgt));
BtrLinux
Privacy Overview
