arch/arm/plat-iop: Use DIV_ROUND_CLOSEST
The kernel.h macro DIV_ROUND_CLOSEST performs the computation (x + d/2)/d
but is perhaps more readable.
The semantic patch that makes this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@haskernel@
#include
@depends on haskernel@
expression x,__divisor;
- (((x) + ((__divisor) / 2)) / (__divisor))
+ DIV_ROUND_CLOSEST(x,__divisor)
Signed-off-by: Julia Lawall
Signed-off-by: Dan Williams
arch/arm/plat-iop/time.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/arm/plat-iop/time.c b/arch/arm/plat-iop/time.c
index 3695bbe..8da95d5 100644
--- a/arch/arm/plat-iop/time.c
+++ b/arch/arm/plat-iop/time.c
@@ -85,7 +85,7 @@ void __init iop_init_time(unsigned long tick_rate)
u32 timer_ctl;
- ticks_per_jiffy = (tick_rate + HZ/2) / HZ;
+ ticks_per_jiffy = DIV_ROUND_CLOSEST(tick_rate, HZ);
ticks_per_usec = tick_rate / 1000000;
next_jiffy_time = 0xffffffff;
iop_tick_rate = tick_rate; |
u32 timer_ctl;
