arch/arm/mach-ux500/cpu-db8500.c: Avoid using ARRAY_AND_SIZE(e) as a function argument
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace ARRAY_AND_SIZE(e) in function argument position to avoid hiding the
arity of the called function.
The semantic match that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression e,f;
f(...,
- ARRAY_AND_SIZE(e)
+ e,ARRAY_SIZE(e)
Signed-off-by: Julia Lawall
Signed-off-by: Linus Walleij
 arch/arm/mach-ux500/cpu-db8500.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/arch/arm/mach-ux500/cpu-db8500.c b/arch/arm/mach-ux500/cpu-db8500.c
index 03ec8a2..23590b7 100644
--- a/arch/arm/mach-ux500/cpu-db8500.c
+++ b/arch/arm/mach-ux500/cpu-db8500.c
@@ -156,7 +156,8 @@ static void __init db8500_add_gpios(struct device *parent)
 		.supports_sleepmode = true,
-	dbx500_add_gpios(parent, ARRAY_AND_SIZE(db8500_gpio_base),
+	dbx500_add_gpios(parent, db8500_gpio_base,
+			 ARRAY_SIZE(db8500_gpio_base),
 			 IRQ_DB8500_GPIO0, &pdata);
 	dbx500_add_pinctrl(parent, "pinctrl-db8500", U8500_PRCMU_BASE);
BtrLinux
Privacy Overview
