arch/arm/mach-omap2/dpll3xxx.c: drop if around WARN_ON
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Just use WARN_ON rather than an if containing only WARN_ON(1).
A simplified version of the semantic patch that makes this transformation
is as follows: (http://coccinelle.lip6.fr/)
expression e;
- if (e) WARN_ON(1);
+ WARN_ON(e);
Signed-off-by: Julia Lawall
Signed-off-by: Tony Lindgren
 arch/arm/mach-omap2/dpll3xxx.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/arch/arm/mach-omap2/dpll3xxx.c b/arch/arm/mach-omap2/dpll3xxx.c
index fafb28c..bebd7ed 100644
--- a/arch/arm/mach-omap2/dpll3xxx.c
+++ b/arch/arm/mach-omap2/dpll3xxx.c
@@ -485,8 +485,7 @@ int omap3_noncore_dpll_set_rate(struct clk_hw *hw, unsigned long rate,
 		if (!cpu_is_omap44xx() && !cpu_is_omap3630()) {
 			freqsel = _omap3_dpll_compute_freqsel(clk,
 						dd->last_rounded_n);
-			if (!freqsel)
-				WARN_ON(1);
+			WARN_ON(!freqsel);
 		pr_debug("%s: %s: set rate: locking rate to %lu.\n",
BtrLinux
Privacy Overview
