arch/arm/mach-omap2: Remove unecessary semicolon
Author: Peter Senna Tschudin <peter.senna@gmail.com>
Found by http://coccinelle.lip6.fr/
Signed-off-by: Peter Senna Tschudin
Signed-off-by: Tony Lindgren
 arch/arm/mach-omap2/board-flash.c          | 2 +-
 arch/arm/mach-omap2/clkt_clksel.c          | 2 +-
 arch/arm/mach-omap2/mux.c                  | 2 +-
 arch/arm/mach-omap2/omap_hwmod_3xxx_data.c | 6 +++---
 arch/arm/mach-omap2/pm-debug.c             | 2 +-
 5 files changed, 7 insertions(+), 7 deletions(-)
diff --git a/arch/arm/mach-omap2/board-flash.c b/arch/arm/mach-omap2/board-flash.c
index 0cabe61..e642acf 100644
--- a/arch/arm/mach-omap2/board-flash.c
+++ b/arch/arm/mach-omap2/board-flash.c
@@ -218,7 +218,7 @@ void __init board_flash_init(struct flash_partitions partition_info[],
 			if (onenandcs > GPMC_CS_NUM)
 				onenandcs = cs;
 			break;
 		cs++;
diff --git a/arch/arm/mach-omap2/clkt_clksel.c b/arch/arm/mach-omap2/clkt_clksel.c
index eaed390..3ff2211 100644
--- a/arch/arm/mach-omap2/clkt_clksel.c
+++ b/arch/arm/mach-omap2/clkt_clksel.c
@@ -382,7 +382,7 @@ void omap2_init_clksel_parent(struct clk *clk)
 						  __clk_get_name(parent) :
 						 "NULL"));
 					clk_reparent(clk, clks->parent);
 				found = 1;
diff --git a/arch/arm/mach-omap2/mux.c b/arch/arm/mach-omap2/mux.c
index 9fe6829..701e17c 100644
--- a/arch/arm/mach-omap2/mux.c
+++ b/arch/arm/mach-omap2/mux.c
@@ -486,7 +486,7 @@ void omap_hwmod_mux(struct omap_hwmod_mux_info *hmux, u8 state)
 		default:
 			/* Nothing to be done */
 			break;
 		if (val >= 0) {
 			omap_mux_write(pad->partition, val,
diff --git a/arch/arm/mach-omap2/omap_hwmod_3xxx_data.c b/arch/arm/mach-omap2/omap_hwmod_3xxx_data.c
index cc1fad7..82fdb59 100644
--- a/arch/arm/mach-omap2/omap_hwmod_3xxx_data.c
+++ b/arch/arm/mach-omap2/omap_hwmod_3xxx_data.c
@@ -3738,7 +3738,7 @@ int __init omap3xxx_hwmod_init(void)
 	} else {
 		WARN(1, "OMAP3 hwmod family init: unknown chip type\n");
 		return -EINVAL;
 	r = omap_hwmod_register_links(h);
 	if (r < 0)
@@ -3755,7 +3755,7 @@ int __init omap3xxx_hwmod_init(void)
 		   rev == OMAP3430_REV_ES3_0 || rev == OMAP3430_REV_ES3_1 ||
 		   rev == OMAP3430_REV_ES3_1_2) {
 		h = omap3430es2plus_hwmod_ocp_ifs;
 	if (h) {
@@ -3770,7 +3770,7 @@ int __init omap3xxx_hwmod_init(void)
 	} else if (rev == OMAP3430_REV_ES3_0 || rev == OMAP3430_REV_ES3_1 ||
 		h = omap3430_es3plus_hwmod_ocp_ifs;
 	if (h)
diff --git a/arch/arm/mach-omap2/pm-debug.c b/arch/arm/mach-omap2/pm-debug.c
index 3e1345f..46092cd 100644
--- a/arch/arm/mach-omap2/pm-debug.c
+++ b/arch/arm/mach-omap2/pm-debug.c
@@ -168,7 +168,7 @@ static int pm_dbg_open(struct inode *inode, struct file *file)
 	default:
 		return single_open(file, pm_dbg_show_timers,
 			&inode->i_private);
 static const struct file_operations debug_fops = {
