arch/arm/mach-omap1/dma.c: Invert calls to platform_device_put and platform_device_del
Platform_device_del should be called before platform_device_put, as
platform_device_put can delete the structure.
Additionally, improve the error handling code for the call to ioremap, so
that it calls platform_device_put.
The semantic match that finds this problem is:
(http://coccinelle.lip6.fr/)
expression e1,e2;
*platform_device_put(e1);
... when != e1 = e2
*platform_device_del(e1);
Signed-off-by: Julia Lawall
Signed-off-by: Tony Lindgren
arch/arm/mach-omap1/dma.c | 11 ++++++-----
1 file changed, 6 insertions(+), 5 deletions(-)
diff --git a/arch/arm/mach-omap1/dma.c b/arch/arm/mach-omap1/dma.c
index d855934..f5a5220 100644
--- a/arch/arm/mach-omap1/dma.c
+++ b/arch/arm/mach-omap1/dma.c
@@ -284,14 +284,15 @@ static int __init omap1_system_dma_init(void)
dma_base = ioremap(res[0].start, resource_size(&res[0]));
if (!dma_base) {
pr_err("%s: Unable to ioremap\n", __func__);
- return -ENODEV;
+ ret = -ENODEV;
+ goto exit_device_put;
ret = platform_device_add_resources(pdev, res, ARRAY_SIZE(res));
if (ret) {
dev_err(&pdev->dev, "%s: Unable to add resources for %s%d\n",
__func__, pdev->name, pdev->id);
- goto exit_device_del;
p = kzalloc(sizeof(struct omap_system_dma_plat_info), GFP_KERNEL);
@@ -299,7 +300,7 @@ static int __init omap1_system_dma_init(void)
dev_err(&pdev->dev, "%s: Unable to allocate 'p' for %s\n",
__func__, pdev->name);
ret = -ENOMEM;
- goto exit_device_put;
+ goto exit_device_del;
d = kzalloc(sizeof(struct omap_dma_dev_attr), GFP_KERNEL);
@@ -380,10 +381,10 @@ exit_release_d:
kfree(d);
exit_release_p:
kfree(p);
-exit_device_put:
- platform_device_put(pdev);
exit_device_del:
platform_device_del(pdev);
+exit_device_put:
+ platform_device_put(pdev);
return ret;
if (!dma_base) {
- return -ENODEV;
+ ret = -ENODEV;
if (ret) {
ret = -ENOMEM;
kfree(d);
exit_release_p:
kfree(p);
-exit_device_put:
exit_device_del:
+exit_device_put:
return ret;
