arch/arm/mach-kirkwood: Avoid using ARRAY_AND_SIZE(e) as a function argument
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace ARRAY_AND_SIZE(e) in function argument position to avoid hiding the
arity of the called function.
The semantic match that makes this change is as follows:
(http://coccinelle.lip6.fr/)
expression e,f;
f(...,
- ARRAY_AND_SIZE(e)
+ e,ARRAY_SIZE(e)
Signed-off-by: Julia Lawall
Signed-off-by: Jason Cooper
 arch/arm/mach-kirkwood/openrd-setup.c    | 3 ++-
 arch/arm/mach-kirkwood/rd88f6281-setup.c | 4 +++-
 2 files changed, 5 insertions(+), 2 deletions(-)
diff --git a/arch/arm/mach-kirkwood/openrd-setup.c b/arch/arm/mach-kirkwood/openrd-setup.c
index 6a6eb54..e5cf841 100644
--- a/arch/arm/mach-kirkwood/openrd-setup.c
+++ b/arch/arm/mach-kirkwood/openrd-setup.c
@@ -158,7 +158,8 @@ static void __init openrd_init(void)
 	kirkwood_mpp_conf(openrd_mpp_config);
 	kirkwood_uart0_init();
-	kirkwood_nand_init(ARRAY_AND_SIZE(openrd_nand_parts), 25);
+	kirkwood_nand_init(openrd_nand_parts, ARRAY_SIZE(openrd_nand_parts),
+			   25);
 	kirkwood_ehci_init();
diff --git a/arch/arm/mach-kirkwood/rd88f6281-setup.c b/arch/arm/mach-kirkwood/rd88f6281-setup.c
index d242231..5154bd2 100644
--- a/arch/arm/mach-kirkwood/rd88f6281-setup.c
+++ b/arch/arm/mach-kirkwood/rd88f6281-setup.c
@@ -87,7 +87,9 @@ static void __init rd88f6281_init(void)
 	kirkwood_init();
 	kirkwood_mpp_conf(rd88f6281_mpp_config);
-	kirkwood_nand_init(ARRAY_AND_SIZE(rd88f6281_nand_parts), 25);
+	kirkwood_nand_init(rd88f6281_nand_parts,
+			   ARRAY_SIZE(rd88f6281_nand_parts),
+			   25);
 	kirkwood_ge00_init(&rd88f6281_ge00_data);
BtrLinux
Privacy Overview
