ALSA: usb-audio: Use kmemdup rather than duplicating its implementation
Author: Thomas Meyer <thomas@m3y3r.de>
The semantic patch that makes this change is available
in scripts/coccinelle/api/memdup.cocci.
Signed-off-by: Thomas Meyer
Signed-off-by: Takashi Iwai
sound/usb/quirks.c | 7 +++----
1 file changed, 3 insertions(+), 4 deletions(-)
diff --git a/sound/usb/quirks.c b/sound/usb/quirks.c
index 2e5bc73..a3ddac0 100644
--- a/sound/usb/quirks.c
+++ b/sound/usb/quirks.c
@@ -137,12 +137,12 @@ static int create_fixed_stream_quirk(struct snd_usb_audio *chip,
return -ENOMEM;
if (fp->nr_rates > 0) {
- rate_table = kmalloc(sizeof(int) * fp->nr_rates, GFP_KERNEL);
+ rate_table = kmemdup(fp->rate_table,
+ sizeof(int) * fp->nr_rates, GFP_KERNEL);
if (!rate_table) {
kfree(fp);
return -ENOMEM;
- memcpy(rate_table, fp->rate_table, sizeof(int) * fp->nr_rates);
fp->rate_table = rate_table;
@@ -224,10 +224,9 @@ static int create_uaxx_quirk(struct snd_usb_audio *chip,
if (altsd->bNumEndpoints != 1)
return -ENXIO;
- fp = kmalloc(sizeof(*fp), GFP_KERNEL);
+ fp = kmemdup(&ua_format, sizeof(*fp), GFP_KERNEL);
if (!fp)
return -ENOMEM;
- memcpy(fp, &ua_format, sizeof(*fp));
fp->iface = altsd->bInterfaceNumber;
fp->endpoint = get_endpoint(alts, 0)->bEndpointAddress; |
return -ENOMEM;
if (!rate_table) {
kfree(fp);
return -ENOMEM;
return -ENXIO;
if (!fp)
return -ENOMEM;
