ALSA: sound/usb: use USB API functions rather than constants
This set of patches introduces calls to the following set of functions:
usb_endpoint_dir_in(epd)
usb_endpoint_dir_out(epd)
usb_endpoint_is_bulk_in(epd)
usb_endpoint_is_bulk_out(epd)
usb_endpoint_is_int_in(epd)
usb_endpoint_is_int_out(epd)
usb_endpoint_num(epd)
usb_endpoint_type(epd)
usb_endpoint_xfer_bulk(epd)
usb_endpoint_xfer_control(epd)
usb_endpoint_xfer_int(epd)
usb_endpoint_xfer_isoc(epd)
In some cases, introducing one of these functions is not possible, and it
just replaces an explicit integer value by one of the following constants:
USB_ENDPOINT_XFER_BULK
USB_ENDPOINT_XFER_CONTROL
USB_ENDPOINT_XFER_INT
USB_ENDPOINT_XFER_ISOC
An extract of the semantic patch that makes these changes is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r1@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bmAttributes & \(USB_ENDPOINT_XFERTYPE_MASK\|3\)) ==
- \(USB_ENDPOINT_XFER_CONTROL\|0\))
+ usb_endpoint_xfer_control(epd)
@r5@ struct usb_endpoint_descriptor *epd; @@
- ((epd->bEndpointAddress & \(USB_ENDPOINT_DIR_MASK\|0x80\)) ==
-  \(USB_DIR_IN\|0x80\))
+ usb_endpoint_dir_in(epd)
@inc@
#include
@depends on !inc && (r1||r5)@
+ #include
  #include
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/usb/usbmidi.c  | 42 +++++++++++++++++++++---------------------
 sound/usb/usbmixer.c |  6 +++---
 2 files changed, 24 insertions(+), 24 deletions(-)
diff --git a/sound/usb/usbmidi.c b/sound/usb/usbmidi.c
index 6d9f9b1..3a9a9fe 100644
--- a/sound/usb/usbmidi.c
+++ b/sound/usb/usbmidi.c
@@ -1392,8 +1392,8 @@ static int snd_usbmidi_get_ms_info(struct snd_usb_midi* umidi,
 	for (i = 0; i < intfd->bNumEndpoints; ++i) {
 		hostep = &hostif->endpoint[i];
 		ep = get_ep_desc(hostep);
-		if ((ep->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) != USB_ENDPOINT_XFER_BULK &&
-		    (ep->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) != USB_ENDPOINT_XFER_INT)
+		if (usb_endpoint_type(ep) != USB_ENDPOINT_XFER_BULK &&
+		    usb_endpoint_type(ep) != USB_ENDPOINT_XFER_INT)
 			continue;
 		ms_ep = (struct usb_ms_endpoint_descriptor*)hostep->extra;
 		if (hostep->extralen < 4 ||
@@ -1401,15 +1401,15 @@ static int snd_usbmidi_get_ms_info(struct snd_usb_midi* umidi,
 		    ms_ep->bDescriptorType != USB_DT_CS_ENDPOINT ||
 		    ms_ep->bDescriptorSubtype != MS_GENERAL)
 			continue;
-		if ((ep->bEndpointAddress & USB_ENDPOINT_DIR_MASK) == USB_DIR_OUT) {
+		if (usb_endpoint_dir_out(ep)) {
 			if (endpoints[epidx].out_ep) {
 				if (++epidx >= MIDI_MAX_ENDPOINTS) {
 					snd_printk(KERN_WARNING "too many endpoints\n");
 					break;
-			endpoints[epidx].out_ep = ep->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
-			if ((ep->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == USB_ENDPOINT_XFER_INT)
+			endpoints[epidx].out_ep = usb_endpoint_num(ep);
+			if (usb_endpoint_xfer_int(ep))
 				endpoints[epidx].out_interval = ep->bInterval;
 			else if (snd_usb_get_speed(umidi->chip->dev) == USB_SPEED_LOW)
@@ -1428,8 +1428,8 @@ static int snd_usbmidi_get_ms_info(struct snd_usb_midi* umidi,
 					break;
-			endpoints[epidx].in_ep = ep->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
+			endpoints[epidx].in_ep = usb_endpoint_num(ep);
 				endpoints[epidx].in_interval = ep->bInterval;
 				endpoints[epidx].in_interval = 1;
@@ -1495,20 +1495,20 @@ static int snd_usbmidi_detect_endpoints(struct snd_usb_midi* umidi,
 		epd = get_endpoint(hostif, i);
-		if ((epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) != USB_ENDPOINT_XFER_BULK &&
-		    (epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) != USB_ENDPOINT_XFER_INT)
+		if (usb_endpoint_type(epd) != USB_ENDPOINT_XFER_BULK &&
+		    usb_endpoint_type(epd) != USB_ENDPOINT_XFER_INT)
 			continue;
 		if (out_eps < max_endpoints &&
-		    (epd->bEndpointAddress & USB_ENDPOINT_DIR_MASK) == USB_DIR_OUT) {
-			endpoint[out_eps].out_ep = epd->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
-			if ((epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) == USB_ENDPOINT_XFER_INT)
+		    usb_endpoint_dir_out(epd)) {
+			endpoint[out_eps].out_ep = usb_endpoint_num(epd);
+			if (usb_endpoint_xfer_int(epd))
 				endpoint[out_eps].out_interval = epd->bInterval;
 			++out_eps;
 		if (in_eps < max_endpoints &&
-		    (epd->bEndpointAddress & USB_ENDPOINT_DIR_MASK) == USB_DIR_IN) {
-			endpoint[in_eps].in_ep = epd->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
+		    usb_endpoint_dir_in(epd)) {
+			endpoint[in_eps].in_ep = usb_endpoint_num(epd);
 				endpoint[in_eps].in_interval = epd->bInterval;
 			++in_eps;
@@ -1607,21 +1607,21 @@ static int snd_usbmidi_create_endpoints_midiman(struct snd_usb_midi* umidi,
 	epd = get_endpoint(hostif, 0);
-	if ((epd->bEndpointAddress & USB_ENDPOINT_DIR_MASK) != USB_DIR_IN ||
-	    (epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) != USB_ENDPOINT_XFER_INT) {
+	if (usb_endpoint_dir_out(epd) ||
+	    usb_endpoint_type(epd) != USB_ENDPOINT_XFER_INT) {
 		snd_printdd(KERN_ERR "endpoint[0] isn't interrupt\n");
 		return -ENXIO;
 	epd = get_endpoint(hostif, 2);
-	if ((epd->bEndpointAddress & USB_ENDPOINT_DIR_MASK) != USB_DIR_OUT ||
-	    (epd->bmAttributes & USB_ENDPOINT_XFERTYPE_MASK) != USB_ENDPOINT_XFER_BULK) {
+	if (usb_endpoint_dir_in(epd) ||
+	    usb_endpoint_type(epd) != USB_ENDPOINT_XFER_BULK) {
 		snd_printdd(KERN_ERR "endpoint[2] isn't bulk output\n");
 		return -ENXIO;
 	if (endpoint->out_cables > 0x0001) {
 		epd = get_endpoint(hostif, 4);
 			snd_printdd(KERN_ERR "endpoint[4] isn't bulk output\n");
 			return -ENXIO;
diff --git a/sound/usb/usbmixer.c b/sound/usb/usbmixer.c
index a492461..9ce626f 100644
--- a/sound/usb/usbmixer.c
+++ b/sound/usb/usbmixer.c
@@ -1755,11 +1755,11 @@ static int snd_usb_mixer_status_create(struct usb_mixer_interface *mixer)
 	if (get_iface_desc(hostif)->bNumEndpoints < 1)
 		return 0;
 	ep = get_endpoint(hostif, 0);
-	if ((ep->bEndpointAddress & USB_ENDPOINT_DIR_MASK) != USB_DIR_IN ||
+	if (usb_endpoint_dir_out(ep) ||
 		return 0;
-	epnum = ep->bEndpointAddress & USB_ENDPOINT_NUMBER_MASK;
+	epnum = usb_endpoint_num(ep);
 	buffer_length = le16_to_cpu(ep->wMaxPacketSize);
 	transfer_buffer = kmalloc(buffer_length, GFP_KERNEL);
 	if (!transfer_buffer)
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
