ALSA: sound/pci/pcxhr/pcxhr.c: introduce missing kfree and pci_disable_device
Error handling code following a kzalloc should free the allocated data.
The error handling code is adjusted to call pci_disable_device(pci); as
well, as done later in the function
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f = E
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/pci/pcxhr/pcxhr.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/sound/pci/pcxhr/pcxhr.c b/sound/pci/pcxhr/pcxhr.c
index 0e06c6c..73de6e9 100644
--- a/sound/pci/pcxhr/pcxhr.c
+++ b/sound/pci/pcxhr/pcxhr.c
@@ -1229,8 +1229,11 @@ static int __devinit pcxhr_probe(struct pci_dev *pci, const struct pci_device_id
 		return -ENOMEM;
-	if (snd_BUG_ON(pci_id->driver_data >= PCI_ID_LAST))
+	if (snd_BUG_ON(pci_id->driver_data >= PCI_ID_LAST)) {
+		kfree(mgr);
+		pci_disable_device(pci);
 		return -ENODEV;
 	card_name = pcxhr_board_params[pci_id->driver_data].board_name;
 	mgr->playback_chips = pcxhr_board_params[pci_id->driver_data].playback_chips;
 	mgr->capture_chips  = pcxhr_board_params[pci_id->driver_data].capture_chips; |
 		return -ENOMEM;
+		kfree(mgr);
 		return -ENODEV;
