ALSA: sound/pci/ctxfi/ctatc.c: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Initialize err before returning on failure, as done elsewhere in the
function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/pci/ctxfi/ctatc.c | 4 +++-
 1 file changed, 3 insertions(+), 1 deletion(-)
diff --git a/sound/pci/ctxfi/ctatc.c b/sound/pci/ctxfi/ctatc.c
index 8e40262..2f6e9c7 100644
--- a/sound/pci/ctxfi/ctatc.c
+++ b/sound/pci/ctxfi/ctatc.c
@@ -1725,8 +1725,10 @@ int __devinit ct_atc_create(struct snd_card *card, struct pci_dev *pci,
 	atc_connect_resources(atc);
 	atc->timer = ct_timer_new(atc);
-	if (!atc->timer)
+	if (!atc->timer) {
+		err = -ENOMEM;
 		goto error1;
 	err = snd_device_new(card, SNDRV_DEV_LOWLEVEL, atc, &ops);
 	if (err < 0)
BtrLinux
Privacy Overview
