ALSA: sound/parisc: Move dereference after NULL test
If the NULL test on h is needed in snd_harmony_mixer_init, then the
dereference should be after the NULL test.
Actually, there is a sequence of calls: snd_harmony_create, then
snd_harmony_pcm_init, and then snd_harmony_mixer_init.  snd_harmony_create
initializes h, but may indeed leave it as NULL.  There was no NULL test at
the beginning of snd_harmony_pcm_init, so I have added one.  The NULL test
in snd_harmony_mixer_init is then not necessary, but in case the ordering
of the calls changes, I have left it, and moved the dereference after it.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
@match exists@
expression x, E;
identifier fld;
* x->fld
  ... when != \(x = E\|&x\)
* x == NULL
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/parisc/harmony.c | 6 +++++-
 1 file changed, 5 insertions(+), 1 deletion(-)
diff --git a/sound/parisc/harmony.c b/sound/parisc/harmony.c
index e924492..f47f9e2 100644
--- a/sound/parisc/harmony.c
+++ b/sound/parisc/harmony.c
@@ -624,6 +624,9 @@ snd_harmony_pcm_init(struct snd_harmony *h)
 	struct snd_pcm *pcm;
 	int err;
+	if (snd_BUG_ON(!h))
+		return -EINVAL;
 	harmony_disable_interrupts(h);
    	err = snd_pcm_new(h->card, "harmony", 0, 1, 1, &pcm);
@@ -865,11 +868,12 @@ snd_harmony_mixer_reset(struct snd_harmony *h)
 static int __devinit
 snd_harmony_mixer_init(struct snd_harmony *h)
-	struct snd_card *card = h->card;
+	struct snd_card *card;
 	int idx, err;
 	if (snd_BUG_ON(!h))
 		return -EINVAL;
+	card = h->card;
 	strcpy(card->mixername, "Harmony Gain control interface");
 	for (idx = 0; idx < HARMONY_CONTROLS; idx++) {
BtrLinux
Privacy Overview
