ALSA: sound/isa/gus: Correct code taking the size of a pointer
sizeof(share_id) is just the size of the pointer. On the other hand,
block->share_id is an array, so its size seems more appropriate.
A simplified version of the semantic patch that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
expression *x;
expression f;
type T;
*f(...,(T)x,...)
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
sound/isa/gus/gus_mem.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/sound/isa/gus/gus_mem.c b/sound/isa/gus/gus_mem.c
index 661205c..af888a0 100644
--- a/sound/isa/gus/gus_mem.c
+++ b/sound/isa/gus/gus_mem.c
@@ -127,7 +127,8 @@ static struct snd_gf1_mem_block *snd_gf1_mem_share(struct snd_gf1_mem * alloc,
!share_id[2] && !share_id[3])
return NULL;
for (block = alloc->first; block; block = block->next)
- if (!memcmp(share_id, block->share_id, sizeof(share_id)))
+ if (!memcmp(share_id, block->share_id,
+ sizeof(block->share_id)))
return block;
return NULL;
return NULL;
return block;
return NULL;
