ALSA: sound/core/pcm_compat.c: adjust array index
Convert array index from the loop bound to the loop index.
A simplified version of the semantic patch that fixes this problem is as
follows: (http://coccinelle.lip6.fr/)
expression e1,e2,ar;
for(e1 = 0; e1 < e2; e1++) { <...
ar[
- e2
+ e1
Signed-off-by: Julia Lawall
Cc:
Signed-off-by: Takashi Iwai
sound/core/pcm_compat.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/sound/core/pcm_compat.c b/sound/core/pcm_compat.c
index 5fb2e28..91cdf94 100644
--- a/sound/core/pcm_compat.c
+++ b/sound/core/pcm_compat.c
@@ -342,7 +342,7 @@ static int snd_pcm_ioctl_xfern_compat(struct snd_pcm_substream *substream,
kfree(bufs);
return -EFAULT;
- bufs[ch] = compat_ptr(ptr);
+ bufs[i] = compat_ptr(ptr);
bufptr++;
if (dir == SNDRV_PCM_STREAM_PLAYBACK) |
kfree(bufs);
return -EFAULT;
bufptr++;
