[ALSA] sound: Use time_before, time_before_eq, etc.
The functions time_before, time_before_eq, time_after, and time_after_eq
are more robust for comparing jiffies against other values.
A simplified version of the semantic patch making this change is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@ change_compare_np @
expression E;
- jiffies <= E
+ time_before_eq(jiffies,E)
- jiffies >= E
+ time_after_eq(jiffies,E)
- jiffies < E
+ time_before(jiffies,E)
- jiffies > E
+ time_after(jiffies,E)
@ include depends on change_compare_np @
#include
@ no_include depends on !include && change_compare_np @
  #include
+ #include
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
Signed-off-by: Jaroslav Kysela
 sound/drivers/serial-u16550.c   | 3 ++-
 sound/soc/s3c24xx/s3c24xx-i2s.c | 3 ++-
 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/sound/drivers/serial-u16550.c b/sound/drivers/serial-u16550.c
index 3958dbd..f415601 100644
--- a/sound/drivers/serial-u16550.c
+++ b/sound/drivers/serial-u16550.c
@@ -43,6 +43,7 @@
 #include <sound/initval.h>
 #include <linux/serial_reg.h>
+#include <linux/jiffies.h>
 #include <asm/io.h>
@@ -694,7 +695,7 @@ static void snd_uart16550_output_write(struct snd_rawmidi_substream *substream)
 			    (uart->adaptor == SNDRV_SERIAL_SOUNDCANVAS ||
 			     uart->adaptor == SNDRV_SERIAL_GENERIC) &&
 			    (uart->prev_out != substream->number ||
-			     jiffies-lasttime > 3*HZ)) {
+			     time_after(jiffies, lasttime + 3*HZ))) {
 				if (snd_uart16550_buffer_can_write(uart, 3)) {
 					/* Roland Soundcanvas part selection */
diff --git a/sound/soc/s3c24xx/s3c24xx-i2s.c b/sound/soc/s3c24xx/s3c24xx-i2s.c
index fe30e0d..9d8af3a 100644
--- a/sound/soc/s3c24xx/s3c24xx-i2s.c
+++ b/sound/soc/s3c24xx/s3c24xx-i2s.c
@@ -24,6 +24,7 @@
 #include <linux/device.h>
 #include <linux/delay.h>
 #include <linux/clk.h>
 #include <sound/driver.h>
 #include <sound/core.h>
 #include <sound/pcm.h>
@@ -185,7 +186,7 @@ static int s3c24xx_snd_lrsync(void)
 		if (iiscon & S3C2410_IISCON_LRINDEX)
 			break;
-		if (timeout < jiffies)
+		if (time_after(jiffies, timeout))
 			return -ETIMEDOUT;
BtrLinux
Privacy Overview
