ALSA: sound: Move dereference after NULL test and drop unnecessary NULL tests
In pcm.c, if the NULL test on pcm is needed, then the dereference should be
after the NULL test.
In dummy.c and ali5451.c, the context of the calls to
snd_card_dummy_new_mixer and snd_ali_free_voice show that dummy and pvoice,
respectively cannot be NULL.
A simplified version of the semantic match that detects this problem is as
follows (http://coccinelle.lip6.fr/):
@match exists@
expression x, E;
identifier fld;
* x->fld
  ... when != \(x = E\|&x\)
* x == NULL
Signed-off-by: Julia Lawall
Signed-off-by: Takashi Iwai
 sound/core/pcm.c            | 5 +++--
 sound/drivers/dummy.c       | 2 --
 sound/pci/ali5451/ali5451.c | 2 +-
 3 files changed, 4 insertions(+), 5 deletions(-)
diff --git a/sound/core/pcm.c b/sound/core/pcm.c
index 0c14401..c69c60b 100644
--- a/sound/core/pcm.c
+++ b/sound/core/pcm.c
@@ -953,11 +953,12 @@ static int snd_pcm_dev_register(struct snd_device *device)
 	struct snd_pcm_substream *substream;
 	struct snd_pcm_notify *notify;
 	char str[16];
-	struct snd_pcm *pcm = device->device_data;
+	struct snd_pcm *pcm;
 	struct device *dev;
-	if (snd_BUG_ON(!pcm || !device))
+	if (snd_BUG_ON(!device || !device->device_data))
 		return -ENXIO;
+	pcm = device->device_data;
 	mutex_lock(&register_mutex);
 	err = snd_pcm_add(pcm);
 	if (err) {
diff --git a/sound/drivers/dummy.c b/sound/drivers/dummy.c
index 6ba066c..146ef00 100644
--- a/sound/drivers/dummy.c
+++ b/sound/drivers/dummy.c
@@ -808,8 +808,6 @@ static int __devinit snd_card_dummy_new_mixer(struct snd_dummy *dummy)
 	unsigned int idx;
 	int err;
-	if (snd_BUG_ON(!dummy))
-		return -EINVAL;
 	spin_lock_init(&dummy->mixer_lock);
 	strcpy(card->mixername, "Dummy Mixer");
diff --git a/sound/pci/ali5451/ali5451.c b/sound/pci/ali5451/ali5451.c
index b458d20..aaf4da6 100644
--- a/sound/pci/ali5451/ali5451.c
+++ b/sound/pci/ali5451/ali5451.c
@@ -973,7 +973,7 @@ static void snd_ali_free_voice(struct snd_ali * codec,
 	void *private_data;
 	snd_ali_printk("free_voice: channel=%d\n",pvoice->number);
-	if (pvoice == NULL || !pvoice->use)
+	if (!pvoice->use)
 		return;
 	snd_ali_clear_voices(codec, pvoice->number, pvoice->number);
 	spin_lock_irq(&codec->voice_alloc);
BtrLinux
Privacy Overview
