sound/core/pcm_native.c | 26 +++++++++++++-------------
1 file changed, 13 insertions(+), 13 deletions(-)
diff --git a/sound/core/pcm_native.c b/sound/core/pcm_native.c
index a8b27cd..fadd3eb 100644
--- a/sound/core/pcm_native.c
+++ b/sound/core/pcm_native.c
@@ -875,7 +875,7 @@ struct action_ops {
* Note: the stream state might be changed also on failure
* Note2: call with calling stream lock + link lock
-static int snd_pcm_action_group(struct action_ops *ops,
+static int snd_pcm_action_group(const struct action_ops *ops,
struct snd_pcm_substream *substream,
int state, int do_lock)
@@ -932,7 +932,7 @@ static int snd_pcm_action_group(struct action_ops *ops,
* Note: call with stream lock
-static int snd_pcm_action_single(struct action_ops *ops,
+static int snd_pcm_action_single(const struct action_ops *ops,
int state)
@@ -952,7 +952,7 @@ static int snd_pcm_action_single(struct action_ops *ops,
-static int snd_pcm_action(struct action_ops *ops,
+static int snd_pcm_action(const struct action_ops *ops,
int state)
@@ -984,7 +984,7 @@ static int snd_pcm_action(struct action_ops *ops,
* Note: don't use any locks before
-static int snd_pcm_action_lock_irq(struct action_ops *ops,
+static int snd_pcm_action_lock_irq(const struct action_ops *ops,
int state)
@@ -998,7 +998,7 @@ static int snd_pcm_action_lock_irq(struct action_ops *ops,
-static int snd_pcm_action_nonatomic(struct action_ops *ops,
+static int snd_pcm_action_nonatomic(const struct action_ops *ops,
int state)
@@ -1056,7 +1056,7 @@ static void snd_pcm_post_start(struct snd_pcm_substream *substream, int state)
snd_pcm_timer_notify(substream, SNDRV_TIMER_EVENT_MSTART);
-static struct action_ops snd_pcm_action_start = {
+static const struct action_ops snd_pcm_action_start = {
.pre_action = snd_pcm_pre_start,
.do_action = snd_pcm_do_start,
.undo_action = snd_pcm_undo_start,
@@ -1107,7 +1107,7 @@ static void snd_pcm_post_stop(struct snd_pcm_substream *substream, int state)
wake_up(&runtime->tsleep);
-static struct action_ops snd_pcm_action_stop = {
+static const struct action_ops snd_pcm_action_stop = {
.pre_action = snd_pcm_pre_stop,
.do_action = snd_pcm_do_stop,
.post_action = snd_pcm_post_stop
@@ -1224,7 +1224,7 @@ static void snd_pcm_post_pause(struct snd_pcm_substream *substream, int push)
-static struct action_ops snd_pcm_action_pause = {
+static const struct action_ops snd_pcm_action_pause = {
.pre_action = snd_pcm_pre_pause,
.do_action = snd_pcm_do_pause,
.undo_action = snd_pcm_undo_pause,
@@ -1273,7 +1273,7 @@ static void snd_pcm_post_suspend(struct snd_pcm_substream *substream, int state)
-static struct action_ops snd_pcm_action_suspend = {
+static const struct action_ops snd_pcm_action_suspend = {
.pre_action = snd_pcm_pre_suspend,
.do_action = snd_pcm_do_suspend,
.post_action = snd_pcm_post_suspend
@@ -1375,7 +1375,7 @@ static void snd_pcm_post_resume(struct snd_pcm_substream *substream, int state)
snd_pcm_timer_notify(substream, SNDRV_TIMER_EVENT_MRESUME);
-static struct action_ops snd_pcm_action_resume = {
+static const struct action_ops snd_pcm_action_resume = {
.pre_action = snd_pcm_pre_resume,
.do_action = snd_pcm_do_resume,
.undo_action = snd_pcm_undo_resume,
@@ -1478,7 +1478,7 @@ static void snd_pcm_post_reset(struct snd_pcm_substream *substream, int state)
snd_pcm_playback_silence(substream, ULONG_MAX);
-static struct action_ops snd_pcm_action_reset = {
+static const struct action_ops snd_pcm_action_reset = {
.pre_action = snd_pcm_pre_reset,
.do_action = snd_pcm_do_reset,
.post_action = snd_pcm_post_reset
@@ -1522,7 +1522,7 @@ static void snd_pcm_post_prepare(struct snd_pcm_substream *substream, int state)
snd_pcm_set_state(substream, SNDRV_PCM_STATE_PREPARED);
-static struct action_ops snd_pcm_action_prepare = {
+static const struct action_ops snd_pcm_action_prepare = {
.pre_action = snd_pcm_pre_prepare,
.do_action = snd_pcm_do_prepare,
.post_action = snd_pcm_post_prepare
@@ -1618,7 +1618,7 @@ static void snd_pcm_post_drain_init(struct snd_pcm_substream *substream, int sta
-static struct action_ops snd_pcm_action_drain_init = {
+static const struct action_ops snd_pcm_action_drain_init = {
.pre_action = snd_pcm_pre_drain_init,
.do_action = snd_pcm_do_drain_init,
.post_action = snd_pcm_post_drain_init |
