ALSA: lola: Deletion of an unnecessary check before the function call “vfree”
Author: Markus Elfring <elfring@users.sourceforge.net>
The vfree() function performs also input parameter validation. Thus the test
around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Takashi Iwai
 sound/pci/lola/lola_mixer.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/sound/pci/lola/lola_mixer.c b/sound/pci/lola/lola_mixer.c
index 782f4d8..e7fe15d 100644
--- a/sound/pci/lola/lola_mixer.c
+++ b/sound/pci/lola/lola_mixer.c
@@ -108,8 +108,7 @@ int lola_init_pins(struct lola *chip, int dir, int *nidp)
 void lola_free_mixer(struct lola *chip)
-	if (chip->mixer.array_saved)
-		vfree(chip->mixer.array_saved);
+	vfree(chip->mixer.array_saved);
 int lola_init_mixer_widget(struct lola *chip, int nid)
BtrLinux
Privacy Overview
