ALSA: hda: Deletion of unnecessary checks before two function calls
Author: Markus Elfring <elfring@users.sourceforge.net>
The functions kfree() and release_firmware() test whether their argument
is NULL and then return immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Takashi Iwai
 sound/pci/hda/hda_codec.c | 3 +--
 sound/pci/hda/hda_intel.c | 3 +--
 2 files changed, 2 insertions(+), 4 deletions(-)
diff --git a/sound/pci/hda/hda_codec.c b/sound/pci/hda/hda_codec.c
index ca98f52..b2d5899 100644
--- a/sound/pci/hda/hda_codec.c
+++ b/sound/pci/hda/hda_codec.c
@@ -834,8 +834,7 @@ static void snd_hda_bus_free(struct hda_bus *bus)
 	WARN_ON(!list_empty(&bus->codec_list));
 	if (bus->workq)
 		flush_workqueue(bus->workq);
-	if (bus->unsol)
-		kfree(bus->unsol);
+	kfree(bus->unsol);
 	if (bus->ops.private_free)
 		bus->ops.private_free(bus);
 	if (bus->workq)
diff --git a/sound/pci/hda/hda_intel.c b/sound/pci/hda/hda_intel.c
index 9ab1e63..91fa959 100644
--- a/sound/pci/hda/hda_intel.c
+++ b/sound/pci/hda/hda_intel.c
@@ -1130,8 +1130,7 @@ static int azx_free(struct azx *chip)
 	pci_disable_device(chip->pci);
 	kfree(chip->azx_dev);
 #ifdef CONFIG_SND_HDA_PATCH_LOADER
-	if (chip->fw)
-		release_firmware(chip->fw);
+	release_firmware(chip->fw);
 #endif
 	if (chip->driver_caps & AZX_DCAPS_I915_POWERWELL) {
 		hda_display_power(false);
BtrLinux
Privacy Overview
