ALSA: hda: Delete an unnecessary check before the function call “snd_info_free_entry”
Author: Markus Elfring <elfring@users.sourceforge.net>
The snd_info_free_entry() function tests whether its argument is NULL and
then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Takashi Iwai
 sound/pci/hda/patch_hdmi.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/sound/pci/hda/patch_hdmi.c b/sound/pci/hda/patch_hdmi.c
index f852734..2f24338 100644
--- a/sound/pci/hda/patch_hdmi.c
+++ b/sound/pci/hda/patch_hdmi.c
@@ -591,7 +591,7 @@ static int eld_proc_new(struct hdmi_spec_per_pin *per_pin, int index)
 static void eld_proc_free(struct hdmi_spec_per_pin *per_pin)
-	if (!per_pin->codec->bus->shutdown && per_pin->proc_entry) {
+	if (!per_pin->codec->bus->shutdown) {
 		snd_info_free_entry(per_pin->proc_entry);
 		per_pin->proc_entry = NULL;
BtrLinux
Privacy Overview
