ALSA: gus: use swap() in snd_ics_put_double()
Author: Fabian Frederick <fabf@skynet.be>
Use kernel.h macro definition.
Thanks to Julia Lawall for Coccinelle scripting support.
Signed-off-by: Fabian Frederick
Signed-off-by: Takashi Iwai
 sound/isa/gus/gus_mixer.c | 9 +++------
 1 file changed, 3 insertions(+), 6 deletions(-)
diff --git a/sound/isa/gus/gus_mixer.c b/sound/isa/gus/gus_mixer.c
index 0dd4341..3b5d9a7 100644
--- a/sound/isa/gus/gus_mixer.c
+++ b/sound/isa/gus/gus_mixer.c
@@ -109,7 +109,7 @@ static int snd_ics_put_double(struct snd_kcontrol *kcontrol, struct snd_ctl_elem
 	unsigned long flags;
 	int addr = kcontrol->private_value & 0xff;
 	int change;
-	unsigned char val1, val2, oval1, oval2, tmp;
+	unsigned char val1, val2, oval1, oval2;
 	val1 = ucontrol->value.integer.value[0] & 127;
 	val2 = ucontrol->value.integer.value[1] & 127;
@@ -120,11 +120,8 @@ static int snd_ics_put_double(struct snd_kcontrol *kcontrol, struct snd_ctl_elem
 	gus->gf1.ics_regs[addr][0] = val1;
 	gus->gf1.ics_regs[addr][1] = val2;
 	if (gus->ics_flag && gus->ics_flipped &&
-	    (addr == SNDRV_ICS_GF1_DEV || addr == SNDRV_ICS_MASTER_DEV)) {
-		tmp = val1;
-		val1 = val2;
-		val2 = tmp;
+	    (addr == SNDRV_ICS_GF1_DEV || addr == SNDRV_ICS_MASTER_DEV))
+		swap(val1, val2);
 	addr <<= 3;
 	outb(addr | 0, GUSP(gus, MIXCNTRLPORT));
 	outb(1, GUSP(gus, MIXDATAPORT));
BtrLinux
Privacy Overview
