ALSA: fix possible memory leak in snd_mixer_oss_build_input()
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
uinfo has been allocated in this function and should be
freed before leaving from the error handling cases.
spatch with a semantic match is used to found this problem.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Takashi Iwai
sound/core/oss/mixer_oss.c | 2 ++
1 file changed, 2 insertions(+)
diff --git a/sound/core/oss/mixer_oss.c b/sound/core/oss/mixer_oss.c
index 18297f7..29f6ded 100644
--- a/sound/core/oss/mixer_oss.c
+++ b/sound/core/oss/mixer_oss.c
@@ -1046,6 +1046,7 @@ static int snd_mixer_oss_build_input(struct snd_mixer_oss *mixer, struct snd_mix
if (kctl->info(kctl, uinfo)) {
up_read(&mixer->card->controls_rwsem);
+ kfree(uinfo);
return 0;
strcpy(str, ptr->name);
@@ -1061,6 +1062,7 @@ static int snd_mixer_oss_build_input(struct snd_mixer_oss *mixer, struct snd_mix
uinfo->value.enumerated.item = slot.capture_item;
+ kfree(uinfo);
return 0;
if (!strcmp(uinfo->value.enumerated.name, str)) { |
+ kfree(uinfo);
return 0;
+ kfree(uinfo);
return 0;
